Minneapolis Moline Tractors Discussion Forum
Heavy duty snap ring for steering sector
Daniel (PA)
02-28-2008 14:00:33
My U302 had a heavy duty snap ring to hold the steering sector gear on the vertical steering shaft. Any suggestions for a replacement ring? Listed as 2 1/4" diameter. Much thicker and different style than typical external snap rings. It has beveled ends, not the usual holes for snap ring pliers. Thanks
deadeye012
02-29-2008 08:23:45
 Re: Heavy duty snap ring for steering sector in reply to Daniel (PA), 02-28-2008 14:00:33
McMaster-Carr is another place to look... Just a suggestion....JB
Barnheater
02-28-2008 20:06:43
Try a local heavy truck repair garage, fuller transmissions have alot of large & heavy snap rings like that.
Kevin Meier
02-28-2008 18:50:32
You might want to try the snap ring that goes into an Ih mechanical t/a that holds the cast and bearing assembly on the backgear. I can measure one at work tomorrow if needed.
