Minneapolis Moline Tractors Discussion Forum
MM engine replacement
randerson
02-27-2008 07:18:06
I have a customer that has a Big MO III forklift that was built for the military. I think the engine is a 220-4 gas. I am looking for a replacement engine and was wondering if anyone has one or if anyone can tell me if a 206-4 engine would work. The crankshaft is broke and he was looking at a complete replacement. There is a number on the block which I think is a serial number #1900204. Thanks.
KCfromPA
02-27-2008 19:51:32
 Re: MM engine replacement in reply to randerson, 02-27-2008 07:18:06
If you would keep me in mind. Thank you.
KC fromPA
02-27-2008 13:20:56
Just wondering what will be done with motor taken out? I am interested in it if wanting to sell.
randerson
02-27-2008 14:24:49
 Re: MM engine replacement in reply to KC fromPA, 02-27-2008 13:20:56
When and if we get a replacement, I could ask the customer for you on that question. I know the crank was broke, but I do not know if the journal was ruined. If interested, let me know and I will find out for you. We are located in NW North Dakota and the customer is from N.E. Montana.
MMDEL
02-27-2008 07:46:28
Yes a 206 will work
MMDEL
T.R.K.
02-28-2008 05:48:58
 Re: MM engine replacement in reply to MMDEL, 02-27-2008 07:46:28
Having done this on a Big MO 400 Military:
A 206H or 206L will work, but you need to be sure you have a starter that bolts in the crankcase and works with the ring gear on the flywheel.
Some starters use a bendix and are retained in the crankcase with a setscrew. Other starters use a solenoid-operated drive and are retained to the crankcase by three bolts.
I can't prove the ring gears/flywheels interchange by comparing part numbers in the parts books.
This issue gets very important if your forklift has a torque converter in it, because the flywheel would probably have a special bolt pattern to mount the torque converter.
randerson
02-27-2008 09:55:38
Thank you. I'll let the customer know.
Cody
02-28-2008 05:53:06
 Re: MM engine replacement in reply to randerson, 02-27-2008 09:55:38
I have a 220 military version engine that I'd sell. 931-212-3602
