Minneapolis Moline Tractors Discussion Forum
Gaskets
Jerry Grant
02-26-2008 07:03:32
Looking for some gaskets for the oil cup for the air cleaner, the oil filter shell and the bolt that holds the filter shell on. These are for my 46 ZTN. The normal sources like Welters and Wendell Everett do not have them. Do you guys make these and if so, from what? Your help would be appreciated.
T.R.K.
02-26-2008 17:52:31
 Re: Gaskets in reply to Jerry Grant, 02-26-2008 07:03:32
Jerry,
on my '40 RTS I re-arched the spring on the air cleaner cup so it fit up snugly against the housing. I guess you could make a gasket out of rubberized cork gasket material if you really want one. (My '38 ZTU had a 206 in it and used the later filter that has no gasket between cup and housing.)
For the oil filter canister, The gasket has always been in the box with the filter I got from NAPA. (1108)
That copper washer on the oil filter bolt can probably be gotten from McMaster-Carr (www.Mcmaster.com-I think)
I have also found a useable copper washer in an assortment of copper oil drain plug washers from the Auto parts store. Usually in a red package that says "Help" on it. Its been a while since I got those and I don't know if they are still available.
Don't overtighten that bolt in the canister! If you collapse the end it will never seal. And yes, they do tend to ooze a bit there. . .
Jerry Grant
02-27-2008 12:18:47
 Re: Gaskets in reply to T.R.K., 02-26-2008 17:52:31
Thanks for the good advise.
