Minneapolis Moline Tractors Discussion Forum
MM R Hood Hinges ?
OL-TIMER
02-26-2008 05:46:28
Would any of you good fellers know where i can find the proper hinge material to put a set on a R hood.I have one that is beyond repair.I dont see any in MCMasters.Any help truely appreciated.
Cast Iron Dave
02-28-2008 18:22:35
 Re: MM R Hood Hinges ? in reply to OL-TIMER, 02-26-2008 05:46:28
NAPA auto parts offers a new hinge that is just like the R's. Don't recall the part number but is a Balkamp item.
T.R.K.
02-26-2008 18:04:09
you know, i bet Arnie Lillo in MN can help with a hinge. I don't know his # though.
What I did on my '38 ZTU that had one side panel torn off was to cut and form a series of 18 guage rectangles the same width and length and cross section as each section of the original hinge, between the loops on the opposing piece, and thread them onto the other 'good' side of the hinge (The pin is 1/4" dia. and can be removed although it takes some doing.) Then I clamped the side panel and hood together and my cousin welded each rectangle to the hood. You can't tell its been fixed with the hood mounted on the tractor.
Jerry Grant
02-27-2008 12:26:56
 Re: MM R Hood Hinges ? in reply to T.R.K., 02-26-2008 18:04:09
Wow, that is really creative.
Jerry Grant
02-26-2008 07:22:09
Assuming they are similar to the continuous hinges on the Z's. I had to replace the continuous hinges on my ZTN. I got them from McMaster-Carr's catalog. I could not find hinges with knuckles as long as the originals, so I comproimised with a little shorter knuckles. You can find them in the index under continuous hinges. Jerry
OL-TIMER
02-27-2008 03:08:03
 Re: MM R Hood Hinges ? in reply to Jerry Grant, 02-26-2008 07:22:09
OK i found them in McMaster now.I really wanted to stay with proper size but if not these will work. Jerry did yours look pretty good? How did ya mount them ? spot weld.
Jerry Grant
02-27-2008 12:24:58
 Re: MM R Hood Hinges ? in reply to OL-TIMER, 02-27-2008 03:08:03
I could never find the hinges with the wider knockles. However, I think mine turned out really nice. I spot welded them in. However, if you ordered them with some holes, you could easily plug weld them in and finish them off with a grinder.
