Minneapolis Moline Tractors Discussion Forum
M602-LP - #3 full of water
Jeff Polasek
02-19-2008 10:13:08
Howdy all,
My brother-in-law has a M602-LP with a front end loader. It had been sitting for over 6 months and he asked me to help him get it started.
After a tune-up (new points, condenser, plugs, wires, etc) the tractor was running like a champ. :-)
Three weeks later he calls and says he can't get the tractor to turn over. When I get there and hit the starter button, the motor acts like it is locked up (the starter hits, but the motor does not turn).
When I pull the plugs, i find cylinder 3 is FULL OF WATER! Cyl 1, 2, and 4 look fine. The tractor had been running fine (according to my BIL) when he parked it. Open the radiator and guess what..no water there...
on a good note, there is no water in the oil that I can see.
I have not started a tear down of the motor yet.
Any and all information welcome...I am a newbie to tractors (work mainly on old dodge cars for fun).
I am assuming the head gasket is leaking water into #3. So what is the recommendations? new gaskets? what else should/needs to be changed? Where is a good place to get gaskets and other parts that are needed to get her running again?
Thanks
R/T Jeff Polasek
Curt Cooke
02-19-2008 10:48:39
 Re: M602-LP - #3 full of water in reply to Jeff Polasek, 02-19-2008 10:13:08
I fear than you are going to find that head cracked. You may get lucky and find that it's a head gasket (I never get lucky) but my guess is a crack. You may be able to have the crack repaired but I would get the casting number off the head and commence a search for a replacement.
R.D.F.
02-19-2008 14:29:25
 Re: M602-LP - #3 full of water in reply to Curt Cooke, 02-19-2008 10:48:39
Jeff, we have lots of MM parts here. If you do need a head we probably can help, also have gaskets on hand, River Dale Farms, 920 295 3278
