Minneapolis Moline Tractors Discussion Forum
403 diesel
buzzuca
02-18-2008 05:01:29
Anybody ever try to do this? I can`t see why it would not work. 6 inch crank from a 403 and the short pistons that welters sell? See any reason why it would not stay together?
Wonder why moline did not do this?
freddy
02-18-2008 12:38:40
 Re: 403 diesel in reply to buzzuca, 02-18-2008 05:01:29
MM did make a 605 diesel. The rods would be needed from a 605D with blocks and heads. A M5/602 diesel block checked for crank obstructions might also work. A 504LP and Diesel use the same crank so maybe the same is true on a 403 crank. I would think an older 4 cylinder diesel block (D336 5 Star) and the 403 crank would have the same crank seal. If not then some fabrication would be necessary.
propane puller
02-18-2008 09:44:01
I think the high compression and hammering of a diesel would make for a short lifespan with that set up.
