Minneapolis Moline Tractors Discussion Forum
G705 dimension
Chief 83
02-13-2008 21:05:03
I have purchased a G705 (Massey 97) and need to know the dimensions for shipping. I have the weight at 8,000 hopefully that's correct. Tractor Data does not show this info. Thanks for the help.
Howard H.
02-16-2008 18:32:00
 Re: G705 dimension in reply to Chief 83, 02-13-2008 21:05:03
Hey Chief -
This one measured as follows:
152" - nose to end of drawbar 76" - height (to top of steering wheel - not muffler)
87" - width of rears
70" - width of front axle (spindle cap to cap)
third party image
HTH,
Howard
dobber
02-14-2008 12:51:56
Hotline blue book gives 7500-7750 for G705 and 7750-7900 for MF 97 with diesels being a big heavier than LPG models. With full weights, fluid in tires, cab, all hydraulic options I would be surprised at one pushing 10,000 or more. Not the standard car trailer load.
Chief 83
02-14-2008 21:01:16
 Re: G705 dimension in reply to dobber, 02-14-2008 12:51:56
I'm sure weight is going to be and expensive issue. Any ideas on the lenght, width and height? Most shipping companies need this info to provide a quote.
dobber
02-15-2008 09:44:27
 Re: G705 dimension in reply to Chief 83, 02-14-2008 21:01:16
Nope other than it's long but you knew that. Howard or someone will probably measure one for you when they get time.
Howard H.
02-13-2008 21:29:49
I'll try to get the dimensions soon, but a lot depends on how it's weighted.
I picked up one with front wheel weights and inside and outside rear weights and it felt like a JD 4440 on the trailer! (not to mention if it has water in the rears)
Howard
