Minneapolis Moline Tractors Discussion Forum
mm4star hydraulics
thomas maleshaf
02-12-2008 18:06:26
were do you put the fiuld in for the hydraulics on this tracor i cannot seem to find a place for this i am new to this tractor stuff
paulsun
02-14-2008 09:33:26
 Re: mm4star hydraulics in reply to thomas maleshafske, 02-12-2008 18:06:26
If the hole were the dip stick is, put the oil in there.
shinnery
02-12-2008 19:34:20
Never having seen a 4*, if it is like others of that vintage and has the Tel-O Flo three point hydraulics you should have, under the seat, two levers marked rate and cycle. Remove the plate that they are mounted thru (four bolts) fill the hydraulics to within one inch ot the top. Then reinstall the plate and levers. Back on the right rear of that hydraulics assy you should see a pipe plug into the bottom corner, that is the hydraulics drain Later models such as M602 and M670 have a tee screwed in where that plug is and about an 8 inch pipe sticking up from the tee. You fill the upper leg to th level indicated on a dipstick.
Bryce
