Minneapolis Moline Tractors Discussion Forum
Serial number on M-M tractor
DickA
02-12-2008 12:48:41
I just purchased a MM gas tractor with the serial number 207365 on the transmisson. There is also a number 2476656 on the engine. I have looked in the various serial number files for the MM tractors without finding any info on the make or year of the tractor. The person I purchase from only knew it was a MM tractor. The unit runs great,but would like to know what kind
P Luna
02-13-2008 22:17:52
 Re: Serial number on M-M tractor in reply to DickA, 02-12-2008 12:48:41
I don't want to hurt your idea but your "BF will not handle 1000lbs of wieght on front axle.The small spindle and bearings are not this heavy.I broke spindle years ago just from front end bounce across corn rows.Today replacement parts are hard too find and high dollar.Sorry too say but this would be bad crash waiting for place too land. P. Luna
Clint Youse MO
02-13-2008 18:54:55
I would watch putting a bale on the loader it may lift it but it could very easily tip the tractor forward and I dont know if a BF front axle will handle a bale rear three point would probably be ok
JK2
02-12-2008 13:37:21
I checked for your numbers & don't find either the serial number or the engine number to be a good number. Is it possible that there could be number(s) missing from the front of either?
could you give more info? There should also be a model number on the serial tag and at least bore & stroke info on the engine tag. How many cylinders?
Hydraulics?
3 point?
power steering?
hand or foot clutch?
where is the PTO lever?
where is the throttle?
A picture is worth a thousand words.
DickA
02-12-2008 18:19:01
 Re: Serial number on M-M tractor in reply to JK2, 02-12-2008 13:37:21
Picture is posted in the tractor photo gallery.
DickA
02-12-2008 15:01:54
It is a 4 cylinder Flat head.Hydraulic yes,3 point yes,power steering no,foot clutch,no PTO,throttle is on the steering wheel columm.After some reseach i think it maybe a BF or BG model.
Don't know how to attach a picture here, but could send via e-mail.
P Luna
02-12-2008 19:06:18
 Re: Serial number on M-M tractor in reply to DickA, 02-12-2008 15:01:54
Your tractor is "BF" more info posted with picture.Like the loader. Hope this helps P.Luna
DickA
02-13-2008 14:07:18
 Re: Serial number on M-M tractor in reply to P Luna, 02-12-2008 19:06:18
Thank for the info,now I can purchase some manuals for the tractor. I looked for the serial number on the rail to much paint will have to remove and see, no tag on rail. As for the loader no tags,names,serial number I can find. No idea what the capacity is,but hope it will lift a 1000# hay ball. Sorry I can not give you anymore info, if you have any more questions let me know.
