Minneapolis Moline Tractors Discussion Forum
Propane Comp Ratio G-1000 Turbo
Hand Culcth
02-03-2008 21:24:04
What is the highest compression Ratio I good run on Propane with or without a turbo? 18? 16? no Turbo. Maybe 14 with Turbo? What do you guys think????
LW
02-04-2008 08:09:54
 Re: Propane Comp Ratio G-1000 Turbo in reply to Hand Culcth, 02-03-2008 21:24:04
About 7.5 to 8 w/turbo and 13 without is very temper-mental.
lpTurbo
02-04-2008 04:13:44
WHY do you want to run that high of compression? All the problems you will have at 14 or 16 to 1 will never be worth the very few horsepower you will gain. A MM diesel only had 15 to 1 compression.
Hand Culcth
02-04-2008 08:19:07
 Re: Propane Comp Ratio G-1000 Turbo in reply to lpTurbo, 02-04-2008 04:13:44
I am going to make a gooooo d screamer. Thinking about water injection too. The Air Resorce Board here in califorina will fine us for running those somkers on diesel here in California. We are also considering changing over 10 trucks with
350 Cummins to propane with the Natural Gas ignition set-ups. The trucks currently have 14.5 to 1 ratio. So!!!!! !! Please give me a few gooooo d thoughts. Whats the highest ratio on propane anyone has played around with?????
lpTurbo
02-04-2008 08:41:09
 Re: Propane Comp Ratio G-1000 Turbo in reply to Hand Culcth, 02-04-2008 08:19:07
12:1 without a turbo is about the best. Minus 1 for ever 15 lbs of boost.
