Minneapolis Moline Tractors Discussion Forum
585 oil cooler
FM-M
02-02-2008 18:33:20
Does anyone out there know where to find a good oil cooler for the 585 in my A4T-1400? The one on it leaks oil into the water and water in the oil. I think someone forgot to drain it once. Took it off and you can blow air into it and it comes out where it shouldn't. It is the old round cylinder shaped one, not the flat one like on a 1355. If not, is there any way to have it repaired, looks like brass ends maybe soldered together, but I can't imagine how it is sealed with all of the little tubes that you can see looking through the openings. Thanks
Doddsracing
02-10-2008 19:24:54
 Re: 585 oil cooler in reply to FM-M, 02-02-2008 18:33:20
I have this oil cooler if you still need one.
jakeinci
02-06-2008 14:29:32
Any good Radiator shop should be able to repair it.
todd08
02-03-2008 05:52:16
I would sell you one for $275. call me at 785-899-4190
freddy
02-02-2008 21:23:40
Our 1350 diesel has the one your talking about. our A4t -1400 has the external oil filters. I don't know if the G1355 at north 81 tractor in Wichita has the round cooler? I could go and look thursday?
Howard H.
02-02-2008 19:17:35
Can you post a pic??
A lot of the HD800's out here have/had oil coolers - they are cylindrical in shape - about 2 inches in diameter and 12 inches or so long...
I haven't seen one one either tractor you mentioned to know what you are after...
Howard
