Minneapolis Moline Tractors Discussion Forum
MM G Red Wheel Paint Code Needed
Jeff A. Gravert
01-31-2008 20:38:39
I have a 1949 4 cyl. G to paint for a customer, I have the silver and the prairie gold colors. What is the number or formula for the red used on the wheels? ANy help would be appreciated. Thanks Jeff @ Gravert Restoration 308-946-2146 day shop phone
Jim Parisot
02-01-2008 10:50:56
 Re: MM G Red Wheel Paint Code Needed in reply to Jeff A. Gravert, 01-31-2008 20:38:39
Jeff, the correct color in PPG acrylic enamel is DAR 72083 H. It is a fleet color that Roger Mohr had matched to the MM red many moons ago. I have several NOS red parts and this color is as close as you will come to correct. Hope this helps.
Jim
Jeff A. Gravert
02-02-2008 06:37:03
 Re: MM G Red Wheel Paint Code Needed in reply to Jim Parisot, 02-01-2008 10:50:56
Thanks for your help guys. Tractor is in the booth and needs to keep moving forward. Very much appreciated. Jeff
Aberdale Farm
02-01-2008 03:57:00
I have two PPG color codes that are called "Minneapolis Moline Red". Thay are 71528 and 70385. I'm not sure which one is correct for a G.
What paint code did you select for the Prairie Gold?
Dale
