Minneapolis Moline Tractors Discussion Forum
MM wheel weights
john graham
01-31-2008 11:10:36
I just picked up some MM wheel weights. I never thought about it before, but what era tractors were these for?
They are about 110 lbs, have MM cast into them, but they have eight bolt holes, plus two futher out. I was expecting to get the weights that had only 4 bolt holes. I have other MM's , but was wanting to put these on an early R.
What do you guys think? Were these later or are they ok for an old R? John
Clint Youse MO
02-01-2008 20:23:01
 Re: MM wheel weights in reply to john graham, 01-31-2008 11:10:36
I would use them wieghts could be added any time we got them mixed and matched around our place try to keep them as sets of 2 when putting them on but they get put on either way.
Alan K
01-31-2008 20:37:55
Yes the 8 hole are the later ones. 10A373 I think is the number. Ive seen the 4 hole ones on the early 1960 models from the factory in literature. The outer holes or slots are hand holds. I think they would be fine ( I wont tell ).
molinegb
01-31-2008 13:25:10
My early RT book shows UT518 weights with eight holes. 4 bolts for 1 or 2 weights. Eight bolts for 3 weights.Also shows RT684 for front
