Minneapolis Moline Tractors Discussion Forum
Parts breakdown of G rear end
craney
01-29-2008 14:41:43
Hi there, just wondering if someone would have a picture of a parts breakdown for a G tractor rear end. I have a G rear end that i need to take apart and fix, but would like to see what is there before I start tearing apart.
deadeye012
01-30-2008 14:51:53
 Re: Parts breakdown of G rear end in reply to craney, 01-29-2008 14:41:43
Which G do you want??? I have countershaft and gears - upper and lower, differential group 1 and group 2 for "GTB". Is that what you are looking for???
craney
01-30-2008 19:29:37
 Re: Parts breakdown of G rear end in reply to deadeye012, 01-30-2008 14:51:53
Hi Deadeye, I'm looking for the area where the input shaft goes into the trans...Thanks!
deadeye012
01-31-2008 04:33:15
 Re: Parts breakdown of G rear end in reply to craney, 01-30-2008 19:29:37
All that the parts book has is the shafts with the gears on them. It is not a very discriptive drawing of anything....JB
craney
01-31-2008 06:18:50
 Re: Parts breakdown of G rear end in reply to deadeye012, 01-31-2008 04:33:15
ok, no problem....I took it apart last nightand all that is broke is the input shaft and the housing that holds the bearing in place on the outside of the case. I guess I got lucky that more didn't break! I am going to try and have a shaft made up here and weld the casting. Thanks for all yur help!!
craney
01-29-2008 19:24:27
Thanks for the try, Howard....Anyone else have a picture? Thanks..
Howard H.
01-29-2008 18:07:32
I thought I could scan you a page out of my manuals, but I guess they only go back to GVI's on the big iron... They go back to Z's and U's on the row crops...
Not sure why the dealer wouldn't have had any G manuals...
HH
