Minneapolis Moline Tractors Discussion Forum
670 vs. 5 star
glr62
01-26-2008 18:50:03
Is a 670 just a glorified 5 star. With the closed center hydralics and a cab, brakes are there some place close to major heart replacement.
Luke Miller
01-27-2008 07:12:55
 Re: 670 vs. 5 star in reply to glr62, 01-26-2008 18:50:03
Correct me if I'm wrong. 670=366ci, 5 Star=283ci. Different tin. Easier to work on. Heavier 3pt. Open center hyd pump on front cover of engine (super) All and all a much nicer tractor. IMO Especially Supers!
335LP
01-29-2008 21:54:27
 Re: 670 vs. 5 star in reply to Luke Miller, 01-27-2008 07:12:55
5 Star diesel was 336 and 283 gas engines. I thought all M670 were 336 but yes much better hydraulics on later ones.
glr62
01-27-2008 16:33:36
Ya. I have alaways loked them to till this project. plus on the right side is the 3 speed filter and lines. really gets busy around the brakes
Alan K
01-27-2008 17:38:07
 Re: 670 vs. 5 star in reply to glr62, 01-27-2008 16:33:36
What year 670 do you have? Must be a very late one. The brakes are fairly visible on the earlier models. Can you post a pic or email one?
k schwartz
01-26-2008 20:00:45
don"t know much on differences but my 65 M670 diesel has open center hydrolic gear pump on it located in the back above the PTO. Cabs were dealership optional. Deluxe fenders were installed on most if not all M670"s straight fromt he factory.
Ill John
01-26-2008 19:02:08
Don't follow you, the brakes should be accessable right under the flor plates form the outside.
glr62
01-27-2008 16:28:32
 Re: 670 vs. 5 star in reply to Ill John, 01-26-2008 19:02:08
the hydralic valves are mounted on the right brake and hydralic res mounted on left brake
