Minneapolis Moline Tractors Discussion Forum
bull gear nut torque on UTS
dan osborne
01-17-2008 18:40:19
I had to replace the bull pinion shaft and bull gear on a '50 UTS when the bearing failed and broke some teeth. Ended up replacing diff bearings and races as well. Now I am putting it back together, and am wondering what to torque the 3" nuts on the inside of the trans case that hold the gear to the axle. They were not tight when I dissasembled them. If I over tighten, am I putting excessive preload on the axle bearings? Any advice would be much appreciated!
LW
01-17-2008 20:13:50
 Re: bull gear nut torque on UTS in reply to dan osborne, 01-17-2008 18:40:19
You won't over tighten them, the bearing preload is set buy the shims at the end of the axle controlling the depth the race goes in, a snap ring holds the inside race. Tighten them up best you can and bend the tabs over.
