Minneapolis Moline Tractors Discussion Forum
MM Turbo Diagram
Howard H.
01-17-2008 18:04:45
I found this brochure stuck in some manuals last night and thought it might be interesting to some of you:
third party image
tr96
01-18-2008 06:17:21
 Re: MM Turbo Diagram in reply to Howard H., 01-17-2008 18:04:45
Howard H. will that turbo kit work on a straight 800 (not HD)? Any idea where there might be a turbo for an 800 at?
Howard H.
01-18-2008 06:48:38
 Re: MM Turbo Diagram in reply to tr96, 01-18-2008 06:17:21
I don't know why it wouldn't work on a regular 800. I was surprised to see on this diagram it showing dry exhaust manifolds.
Those three piece manifolds tend to be fairly leaky, anyway, but I guess if all the pieces were in good shape and you had new bands and seals on the joints, it must work pretty good.
Mine were water-cooled exhausts, which are sealed the whole way.
Not sure on where to find a turbo - I would guess any model with the proper compression boost would work OK. But I just ran them - I'm not really a true mechanic.
Howard
john graham
01-17-2008 19:07:19
This is how I rigged a U puller once (sucking air through the carb), but the post below showing a 800 turbo picture, shows it pushing air through the carb??? I didn't know that would work. Is it because it is LP? Mine was gasoline. JG
LW
01-17-2008 20:10:59
 Re: MM Turbo Diagram in reply to john graham, 01-17-2008 19:07:19
The HD 800 lps pulled through the 200D base and the throttle body was mounted on the intake. I looked at one burning methane(hog waste gas), It had 27 heads and only made 2 lbs of boost and was running a generator. I believe it was a 80kw.
