Minneapolis Moline Tractors Discussion Forum
M5 rate cycle levers on telo-flow
Junkman
01-16-2008 10:27:01
Is it possible to replace one of the levers, or will I need the whole plate. Top lever is broke off. Anyone got any parts? Thanks
schrocky
01-16-2008 15:25:57
 Re: M5 rate cycle levers on telo-flow in reply to Junkman, 01-16-2008 10:27:01
We actually made some really nice looking ones for my buddies 602, they do come off of there as stated on here . We made from soft steel , the cast ones get broke off often. There are also short and long ones for whatever reason, I do have a set of shorts I might part with.
Luke Miller
01-16-2008 12:54:30
There is a small roll pin that holds them on. Which one do you need I may have an extra, I'll have to see.
Junkman
01-16-2008 13:01:31
 Re: M5 rate cycle levers on telo-flow in reply to Luke Miller, 01-16-2008 12:54:30
I believe it is the lever that is kind of on top of the other lever, I will double check tonight. Thanks
Alan K
01-16-2008 17:20:21
 Re: M5 rate cycle levers on telo-flow in reply to Junkman, 01-16-2008 13:01:31
I think the top one is the rate lever. They are usually the first to go (more in the way of getting hit I suppose). There was a guy that was making those a few years ago. Ill have to see if I can find his name and number.
