Minneapolis Moline Tractors Discussion Forum
MM implement id
john in wa stat
01-14-2008 09:53:54
third party image
hi guys thanks for taking a look i have an old Moline plow.. i know nothing about this but would like to know about what year it is and model.. it is on wire spoke wheels has 2 plows that plow while 2 or upside down it looks like they flip over and go the other way so 2 plow to the left and when you flip it over the other 2 plow to the right i found some #s on it it looks like 2 letters then 72620 and a nother set of numbers i found on it has a word a bove it but cant make it out then 7284a on the plows it has big yellow letters MM if any one can help i have pics of it i can email anyone who might be able to help thanks
john in wa state
01-16-2008 03:42:49
 Re: MM implement id in reply to john in wa state, 01-14-2008 09:53:54
thanks to al the help i got from yt..i think 300 would be a fair price if any one would like t see more pics of it let me know and ill take them thanks again
john in wa state
01-15-2008 00:36:13
third party image
thanks for all the help at least now i know what it is..i would like to sell it..what do you think would be a fair asking price.. i know the bearings are shot but the wheels still turn and one of the plows is missing a peice you can see it in the pic its the top plow closet to you...and once again i thank you all
Kevin Moschenrose
01-15-2008 08:55:16
 Re: MM implement id in reply to john in wa state, 01-15-2008 00:36:13
A fair market value would be in the neighborhood of 300.00. Givin its present state and it is missing the coulters as well. The coulters for this plow a real hard to find because it uses such a small diameter shaft. These tend to break off much easier. There are some other plow that use the same small size.
Kevin Moschenrose
01-14-2008 23:17:39
Also the last one I saw sell was at Jim Skinners sale in PA. back in October for 1200.00 so I don't really think you want to junk it.
Kevin Moschenrose
01-14-2008 23:14:49
John, That is a model TK tumblebug plow. These came out in both 2 and three bottom types. Also those had either rubber or steel wheels on them. Mne has steel wheels and is also a two bottom. There was also anewer version of this plow called a TW type plow. The main difference is in the up right bolsters whersquare and not round and the tounge and the way it swung was a little different. Also on both models there was two different lengths in the tounge. If has a operation and assy intruction manual for this TK model plow. I can copy for you if you would like. Just email you address and any other type questions you may have. These old gals are real show stoppers at plow demos.
john in wa state
01-14-2008 21:29:10
would any one know about what year it is? i dont us it at all it was gave to me and i thought about scrapping it but wanted to know if it is worth holding on to and fixing and selling..i know it needs bearings and tires other than that i think its all there.. thanks again
71ford100
01-14-2008 23:03:50
 Re: MM implement id in reply to john in wa state, 01-14-2008 21:29:10
Don"t scrap it. Someone near you would buy it as is. If you were closer I could use it for parts for my two on steel.
Alan K
01-14-2008 12:54:51
MM tumblebug plow I think is what they called them. Dont see a lot of those around.
JMS/.MN
01-14-2008 11:40:44
Two bottom pull-type rollover plow. Each end of the field, you make a 180 turn, throws all furrows in the same direction. No deadfurrows.
