Minneapolis Moline Tractors Discussion Forum
4 Star diesel
J Kemp
01-06-2008 15:12:51
Got a 4 star MM Diesel with antifreeze dripping from Clutch bell housing ,, Hoping there is a freezeout plug in there that rusted thru ?,,. Motor not wanting to start right now because of cold weather Or Worse Fear , Inadequet ANTIFREEZE , BUSTED something .,. All Comments and help Welcome , Thank You ,
Howard H.
01-06-2008 17:44:34
 Re: 4 Star diesel in reply to J Kemp, 01-06-2008 15:12:51
Does it show overfull on the dipstick?
I'd pull the pan plug and check for antifreeze in the pan...
I know the water pumps were pretty prone to leak to the inside on 605's, 800's, and HD800's - so I wouldn't worry about a frozen block just yet...
Let us know what you find...
Howard
JK2
01-06-2008 17:24:24
There is normally no coolant in the crankcase portion of the engine. I would suspect that either the crankcase is full of collant from a cracked head/block and going through the rear seal or the coolant is leaking down over the outside of the bell housing from either a block or head.
