Wide Front End for Minne-Moline ZB?
Chuck Herrick
02-25-2000 11:57:03
Did they make a Wide Front End for
the M-M ZB? Will I have a hard time
finding one to convert my ZB?
Would the WFE off a model R fit?
Brian
02-28-2000 19:12:59
 Re: Wide Front End for Minne-Moline ZB? in reply to Chuck Herrick, 02-25-2000 11:57:03
I own a ZBE wide front with square type front adjustable axle. Aftermarket companies also made wide front axles to fit the ZB, R, ZA, etc. My pre 1950 R parts manual and ZB parts manual show different part numbers for the front castings. OEM wide front axles require different front castings than narrow front universal tractors. Aftermarket kits were made to convert narrow front tractors to wide front tractors. Adjustable wide front R's and ZB's (or Z's in general for that matter) are fairly rare. Finding an adjustable wide front could be somewhat difficult. Good luck!
Matt
02-28-2000 05:16:23
The front end of an R, Z, ZA, and ZB are all the same. You can put an R wide front on you ZB and no one will know the differents.
Matt
tim [in]
02-25-2000 23:46:07
i've seen one zb here in indiana with a factory wide front as for the other question , maybe someone else can answer. good luck! =)
