Minneapolis Moline Tractors Discussion Forum
MM 800 engine
mrp
01-01-2008 05:37:48
Can anyone tell me what the difference is between an 800 and a 800hd; also, what can I stroke it out to, is 7" conceivable and bore it out to 5.5 to make almost 1000 cubes? what advice can you give for a puller with this engine? (I've heard the only difference is the intake manifold)
MnM44
01-02-2008 16:53:36
 Re: MM 800 engine in reply to mrp, 01-01-2008 05:37:48
The Hd 800 has much better heads with bigger ports and valves. The blocks bolt on a little differently and the crankcase is much stronger on the HD 800. The cam is differnt as well. Yes you can stroke one to 7 inch but it is easier to use a 605 bottom end and lighter.
