Minneapolis Moline Tractors Discussion Forum
Needing Info.
Turtle Gears
12-30-2007 13:17:11
I'am looking at MM tractor and it has no tag, the motor does it says 283.The owner says he thinks its a UB,does anyone have a pic of one or a place I could go to see one on the internet? Thanks Keith
shinnery
12-30-2007 18:55:00
 Re: Needing Info. in reply to Turtle Gears, 12-30-2007 13:17:11
Schwartz did make an aftermarket wide front for UBs but M-M built UBU, UBE, and UBN versions also. The power steering is it a CharLynn or Behlen built add on? My 54 I gave about $1000 for about 12 years ago and I had to work on the starter immeadiately. Does the three point use a M-M cylinder, mounted on the right side, to function? I think a lot of them were dealer add on.
Bryce
Turtle Gears
12-30-2007 20:04:36
 Re: Needing Info. in reply to shinnery, 12-30-2007 18:55:00
I"ll check the 3pt. and see.Thanks Keith
335LP
12-30-2007 13:45:40
Look at pics in left column under tractor photos or more at minneapolis-moline.com All U series had the 283 except a U302 that had the 221.
Turtle Gears
12-30-2007 13:58:59
 Re: Needing Info. in reply to 335LP, 12-30-2007 13:45:40
Thanks 335LP, I found a photo in photo ads. This UB is LP and has wide front end(swarts?) rear tires aren't much has 3 pt.(shop made)valves on gas tank leak,has good powersterring,runs good,sheet metal is ok. I live in Ark. do you no what one like this would sell for?Thanks Keith
