Minneapolis Moline Tractors Discussion Forum
MM_ZB low oil presure
capt-ugly
12-29-2007 12:20:59
i'm bidding on the ZB with low oil presure ,,what could be the problem ,, oil pump ?? i need soma addvice !!
buzz36
12-29-2007 21:06:27
 Re: MM_ZB low oil presure in reply to capt-ugly, 12-29-2007 12:20:59
first off bid as though things are the worst but know anything is fixable and that may also be a reason to bid up coz you need it and be willing to fix it coz its better then what you have many things can cause low oil pressure most are easy to cure and are common to engines that sit aorund for a period of time
good luck
schrocky
12-29-2007 16:50:38
well that is the Beauty of bidding on something ya know nothin about ! it is probably one or more of the suggested diseases ! BID ACCORDINGLY !
MMDEL
12-29-2007 14:21:57
What do you call low?? Could be!! Oil pressure adj. screw, Stuck relief valve, Oil pump clearance, Pluged intake oil screen,and/or pluged oil filter, Loose bearings, Cracked internal oil line.
MMDEL
