Minneapolis Moline Tractors Discussion Forum
A4T 1600 diesel question
john graham
12-22-2007 07:56:56
I went to change engine oil filter on a 585 dsl. The plate on the pan has no container or filter behind it???
The oil cooler has two spin on filters.
Question is: do I need to get the container and filter for the oil pan, or are the cooler filters a later style that don't require the lower one?
schrocky
12-22-2007 14:14:56
 Re: A4T 1600 diesel question in reply to john graham, 12-22-2007 07:56:56
Capt. is right ...when we rebuilt one before we sold it we switched her over , my 1350 is the same way ! M.T. EARL PAN NOW they actually should all be retrofitted with ext oil pump if they are not.
Jetstardiesel
12-22-2007 15:42:17
 Re: A4T 1600 diesel question in reply to schrocky, 12-22-2007 14:14:56
Not to hijack the thread, but i am in the process of rebuilding my 504 D and can I put an external oil pump on just the same as the 585? Or is it not possible?
john graham
12-22-2007 15:34:37
Schrocky - Thanks for the help. I bought this at your auction, so maybe it is the one you rebuilt??? However, I am pretty sure it does not have the external pump, just a hydraulic pump. So back to my question, is it ok to just use the oil cooler filters? John
schrocky
12-22-2007 16:34:43
 Re: A4T 1600 diesel question in reply to john graham, 12-22-2007 15:34:37
which one did you buy ? The one with the 18.4 duals ? That is the one we worked on and I am sure it has an external pump, I am not sure about the other one but I thought they all did. I know when they were new it was a recall on some. If you are going to work that 585 at all it is worth doing it. You can find them off a 2-150 White almost quicker.We sold a unit in our parts too.My 1350 had a blown engine because it got the oil too hot.I have that puppy puttin out power now and she stays COOL.
john graham
12-23-2007 05:37:10
 Re: A4T 1600 diesel question in reply to schrocky, 12-22-2007 16:34:43
David - No, I got the red one with 23 inch tires. I guess I'm going with replacing the spin on filters and leaving the oil pan empty, since it has run this long??? John
Captainhookerus
12-22-2007 09:29:07
You have an external oil pump, that eleminates the oil pan filter.
J Schwiebert
12-22-2007 08:24:54
I am not the Moline man (other side as in Green) but I thought all 585 engines had spin on filters, but the filters are not all alike. Will need to look.
Freddy
12-22-2007 10:49:42
 Re: A4T 1600 diesel question in reply to J Schwiebert, 12-22-2007 08:24:54
Our 1350 diesel a 1971 model has the filter in the pan.
