Minneapolis Moline Tractors Discussion Forum
R flywheel ringgear
ssssss
12-20-2007 16:53:23
Recently acquired RTI with wore ringgear, starter no longer engages (I triied one from another R to check). Can ringgear be turned over or does it have to be replaced?? Thanks sssss
Roger H MI
12-22-2007 12:28:50
 Re: R flywheel ringgear in reply to ssssss, 12-20-2007 16:53:23
I have flipped the ring gear on U"s before. The trick is to do it fast, heat the old ring gear in three places with torch then drive off quickly. Same with reinstall. Its best to have someone there to help.
Tom Ia
12-21-2007 03:54:14
The ring gear can be turned over. Drive it off and heat it up and drop it back on flipped over.
sssss
12-22-2007 05:13:49
 Re: R flywheel ringgear in reply to Tom Ia, 12-21-2007 03:54:14
thanks for info
