Minneapolis Moline Tractors Discussion Forum
MM 800 HD
Turtle Gears
12-19-2007 15:23:28
Could anyone tell me how to find out if I have a 800 or what,it has no tag on it. It was a LP powerunit and has the tall jugs on it.and is extremely heavy,how can I tell without tearing it down? Thanks! Keith (Yes it is a 6 cly.)
jack c.
12-20-2007 06:23:10
 Re: MM 800 HD in reply to Turtle Gears, 12-19-2007 15:23:28
if this is a 605 , and its not what you need.im interested. i need a head and two blocks. let me know.
oliver 77
12-19-2007 17:11:12
What numbers are stamped in the heads? What are the numbers stamped on the crankcase by the bellhousing?
Turtle Gears
12-21-2007 09:30:10
 Re: MM 800 HD in reply to oliver 77, 12-19-2007 17:11:12
The Heads are GE30F ,The Jugs are 10A150A,The crankcase is CE151.Thanks Keith
Turtle Gears
12-19-2007 20:15:04
I'll look at the numbers tomorrow,I have a HD425LP It has 4232 heads on it.Thanks Keith
Freddy
12-20-2007 17:22:18
 Re: MM 800 HD in reply to Turtle Gears, 12-19-2007 20:15:04
A 425C with 10A4232 heads is a gasoline engine.
Turtle Gears
12-21-2007 09:33:46
 Re: MM 800 HD in reply to Freddy, 12-20-2007 17:22:18
The tag says HD 425-6A is that a 425C?Keith
Freddy
12-21-2007 18:04:37
 Re: MM 800 HD in reply to Turtle Gears, 12-21-2007 09:33:46
There are 425A, 425B's and 425C's. the 425A was a tractor motor (GVI) and the 425B was a power unit. I figured it was based of the 425C if it was a HD. Go Figure. A G900 with a gas engine is a 425c with 4232 heads. They lowered the compression to working levels. the 10A4239 is a typical HD-5 tractor propane head. Power units are always different it seems. our 504hd has 4231 heads on it for up to 5000 ft altitude. but the tractor used 4232 heads. 4233 heads were used on tractors above 5000 ft. Is this engine for sale? on a well or just sitting around?
Turtle Gears
12-21-2007 20:21:45
 Re: MM 800 HD in reply to Freddy, 12-21-2007 18:04:37
I have it here at home and its not in use I'am thinking about selling it or trading it.Give me a call or email me.Thanks Keith 501-345-2910
Turtle Gears
12-20-2007 20:03:26
All I know it set up from factory with LP system on it.And it is a powerunit.Keith
MM 6CYL
12-19-2007 15:35:11
The 800 will have two water outlets on the side of each block. If it just has one outlet & tall blocks then its a 605.
Turtle Gears
12-19-2007 16:21:04
 Re: MM 800 HD in reply to MM 6CYL, 12-19-2007 15:35:11
Thanks it has one outlet per block.Keith
