Minneapolis Moline Tractors Discussion Forum
oil
jesse allen
12-17-2007 17:08:01
does anybody know where to put the oil in the rearend on a mm ub.
rvirgil_KS
12-17-2007 18:13:28
 Re: oil in reply to jesse allen, 12-17-2007 17:08:01
My shop maintenance manual (S-181) page 12 "When changing or adding gear oil,remove the four bolts which hold the gear shift lever socket to the transmission case cover. Lift the gear shift lever assembly out of the transmission case cover and pour the oil through the opening." The capacity of the transmission case is 13 gallons.
Bob
ejr-IA
12-17-2007 17:38:57
Their should be a flat plate on the top deck near the gear shifter to pour the lube in.
