Minneapolis Moline Tractors Discussion Forum
G707
mh444
12-14-2007 18:29:03
I have a G707 when it starts it smokes real bad like it flooded then it smooth out runs fine for 2 to 3 min then dies like it out of fuel. All new filters. Let it set it will start again all the same things happen can anyone help me with this problem
molinegb
12-15-2007 09:11:17
 Re: G707 in reply to mh444, 12-14-2007 18:29:03
Had similar problem with Massey 97. There is a return valve on top of roosa master pump. There is a ball inside that sticks causing the pump to overfill and shut off. I changed valve and cured problem.
Captainhookerus
12-15-2007 07:53:28
Generally when they act like this you have a plugged return line back to the tank. Pressure will build on both sides of pumping plungers and then no injection pressure until return pressure bleeds off.Hope this helps, let us know.
bubby
12-14-2007 21:04:00
Sounds like you have air in the fuel lines. Check that everything is tight and not letting air in. I am not sure how to bleed the air out on a 707, but someone here should know.
bubby
