Minneapolis Moline Tractors Discussion Forum
445 valves and springs
Gary in Neb.
12-12-2007 10:37:11
anyone got any extra valves and springs, keepers, etc for a 445? i'm trying to rebuild a set of heads so i can just switch mine out but dont have any extra valves.
thanks
Gary
JK2
12-12-2007 15:36:15
 Re: 445 valves and springs in reply to Gary in Neb., 12-12-2007 10:37:11
If you have a valve grinder, you can use small block chevy exhaust valves, springs & keepers. You may have to adjust the spring seats to make sure that you don't have spring bind. The engine RPM will not be limited by valve float with these springs so make sure your governor works.
R.D.F.
12-12-2007 13:40:09
We stock new valves and have all the other parts you need, 920 295 3278, Dale and Doug
