Minneapolis Moline Tractors Discussion Forum
ZA BRAKE DRUM NUT
JKC
12-08-2007 12:32:41
I am trying to remove the brake drums from my 1950 ZAU, but am having a very diffucult time getting that large castellated nut loose. It seems that I have tried everything (large wrench, heat, PB Blaster, etc). Can anyone help me with suggesttions on how to remove that large castellated nut (what tool to use, etc.)? Any suggestions would be very much appreciated. Thank you.
jlm
12-09-2007 17:13:48
 Re: ZA BRAKE DRUM NUT in reply to JKC, 12-08-2007 12:32:41
I used a 36 inch pipe wrench while my brother held the brake. Hard pull to break loose then came off easily.
yonson
12-08-2007 16:09:26
Got the castellated nuts loose on my ZAS with hammer & punch in the slots, alternating in several places. Be careful not to touch the threads. The slots get a little dinged up but not everyone has a 3 1/8 (I think) deep socket lying around. RW
PGpower
12-08-2007 14:29:09
I don"t know if they are exactly the same or not, but on my UTU I had to take a hammer and a chisel to get the brake nut loose. Just "chisel" the nut counterclock wise. You can usually grind the nut back into shape, just will have a chisel grove when you are done.
