Minneapolis Moline Tractors Discussion Forum
rod bearings in U-Moline
RSC
12-07-2007 11:52:05
Could anyone tell me what year or by serial number MM started using insert bearings in the U tractor engine?
molinegb
12-07-2007 15:36:36
 Re: rod bearings in U-Moline in reply to RSC, 12-07-2007 11:52:05
Babbited bearings were used on KEA (KTA),KEC (1938-41) U ,KED (UDLX), KEF in 1942 had bearing inserts as did all later U's
molinebob
12-07-2007 12:08:42
acoording to my book on MM I have a 1951 UTS wih the 283A-4 engine in it, In my manual it states that different engines for that year had started to use insert bearings, I got lucky mine had the inserts, I cant remember what engines they said used the babbit ones though, so I am geussing that around 1950 or so is when they started to use insert, I will look later and post again, book is out in the shop, when i get time i will go and get it and look it up for you and post the correct answer.
T.r.K.
12-07-2007 17:01:22
 Re: rod bearings in U-Moline in reply to molinebob, 12-07-2007 12:08:42
for what its worth, my 1960 Federal Mogul catalog says the change in bearings came in the 1948 model year. That is for the gas engines,
I am also thinking that some (most, except a few early ones that were not updated) diesels have an even larger bearing too.
If I recall correctly, the bearings do not interchange. I'm thinking you can't even line bore the crankcase and put a late crank in an early engine.
