Minneapolis Moline Tractors Discussion Forum
moline power unit
ken in texas
11-30-2007 19:27:11
A local man has a moline power unit for sale,In good condition.It is a four cylinder 405 engine used on irrigation well.He is asking $750 for it.Does not have original radiator.Anyone interested.If so I will give you his address. He lives in Matador texas.
ken in texas
12-04-2007 18:02:39
 Re: moline power unit in reply to ken in texas, 11-30-2007 19:27:11
Ichecked this engine today,starts good,no exhast smoke,magneto ignition.Owner has worked on these engines for yearsand it is in good condition.head numbers are10A4207 block numbers are 10A149A . Runs very smooth. I believe it to be a good sound engine.
ken in texas
12-04-2007 08:15:24
Engine runs good and is hooked to a propane bottle for starting.Head numbers are 10A4207. I havent heard it run yet .Owner is a mechanic (elderly) that had a fall, and I ame trying to help him sell the engine.Sorry no photos ,not equiped for that. Will check for ignition and block number.The heads have recently been rebuilt.Will try to get more info later today.
bassndeere
12-03-2007 17:41:25
Hello Ken,
An you tell us more about the engine? Any pictures available? Running, stuck, cracked, head casting numbers, block casting numbers. Dist. or mag?
Thanks, Don
ken in texas
12-01-2007 06:45:01
Failed to say it is a propane powered engine.
dobber
12-01-2007 12:34:56
 Re: moline power unit in reply to ken in texas, 12-01-2007 06:45:01
I bet you meant a 425 ? Some are looking for those for tractors. 336 & 425 MM power units were common at one time.
BMG1
12-01-2007 15:47:47
 Re: moline power unit in reply to dobber, 12-01-2007 12:34:56
A 4 cylinder would probably be a 403 power unit. 425 were all 6 cylinder power units.
