Minneapolis Moline Tractors Discussion Forum
206 motor
molinegb
11-22-2007 05:55:09
Is it common for 206 motors turn #2 rod? I have had 3 with the same problem. In a 1350 Cockshutt number 2 spun. In a 445 # 2 also. And recently a JS3 there was no bolts in #2 cap. It smashed the rod,cap,skirt on block,broke cam,lifter and a push rod.Are all these problems related to bad governors?
T.R.K.
11-22-2007 16:51:12
 Re: 206 motor in reply to molinegb, 11-22-2007 05:55:09
Can only say that the crank in my jet2 was worn most on #1-it was knocking-and the crank from the salvage yard that I sent out to be ground to put back in (So I wouldn't have to tie up the shop for 2-3 weeks waiting on it) had also spun #1.
R's and Zs usually wear #1 most. Its the last to get oil.
