Minneapolis Moline Tractors Discussion Forum
Jetstar 3 wheel weights
molinegb
11-19-2007 16:39:26
Does anyone know if Cockshutt 1350 (MM JS3)used MM wheel weights or did Cockshutt have there own?
Also what loader was used on Cockshutt 1350? I plan to put on a MM loader off a Jetstar 3. I have seen loaders with the Cockshutt decals.
1755
11-21-2007 14:50:25
 Re: Jetstar 3 wheel weights in reply to molinegb, 11-19-2007 16:39:26
they probly used Oliver waights becous the MM waights usualy have MM cast right in them the Oliver ones just have a casting number eather will work but if you have power ajust wheels you have to have a starter waight to clear the brackets on the wheels or turn them around backwards but one set will stick out like there is 2 sets on there
the MM waights that fit were all the same I dont know if they actualy maid Cocksutt waites or not good luck
molinegb
11-21-2007 15:48:23
 Re: Jetstar 3 wheel weights in reply to 1755, 11-21-2007 14:50:25
I checked on a wrecked Jetstar 3 and weight numbers are 10A7395. The weights on the Cockshutt 1350 look like TOC-48. Is that an Oliver # ?
