Minneapolis Moline Tractors Discussion Forum
G1050 sputtering
mike r.
11-03-2007 13:25:10
our 1050 diesel is having some problems running at idle. it also is starting to hesitate when accelerating from idle speed. once the rpms get above 900 it evens out and runs perfect. At idle it feels like it is going to die, it sputters and coughs.
If it were a gas tractor I would assume it maybe needed plugs or a carb clean ect... But it's a diesel and I know nothing about diesel motors at all.
Would this be an injector or possibly fuel pump problem? It has a 504 motor. Any guesses on what the damages would be if I were to take it up to the Agco dealer to get into a pump or new injectors? I assume these parts are getting hard to come accross. Thanks in advance.
Im afraid this problem may be more of a repair cost than the tractor is worth.
James22
11-05-2007 08:12:45
 Re: G1050 sputtering in reply to mike r., 11-03-2007 13:25:10
The local pump shop went thru my injectors and pump which cost about $750. I'm pretty "picky" about clean fuel and apparently the previous owner also was cautious., Consequently the so called "pump head" was in good shape, otherwise it would have cost an additional $750. This place isn't cheap and I expect the prices have gone up 50%, but they do good work. They retipped the injectors and replaced a plastic drive part (wave washer?) in the governor which is prone to failure. Bought a new energy cell which was around $400 from the Agco dealer, so I suspect it would require a King's ransom to get it fixed there. The poor idle sounds like the transfer pump might not be suppling enough fuel to the injection side, or the injection pump plungers are worn enough that it is by-passing/leaking too much fuel at low loads to run properly. Could also be the governor is sticking or worn enough to be unstable at low speeds. However before doing any major surgery, I'd change the fuel filters if not already new, and try it again.
guido
11-21-2007 15:52:08
 Re: G1050 sputtering in reply to James22, 11-05-2007 08:12:45
Hey James22
What is an energy cell?
Guido.
Luke Miller
11-03-2007 19:49:30
Mike, Repairs may not be as bad as you think. I got a G950 this spring and had the injection pump rebuilt for around 400 bucks. It sounds like yours may need some injector work more than anything. Sounds like they are kind of slobbering at first then when RPMs increase they even out. I'd pull them out and have them all checked/rebuilt by a good diesel shop. Agco dealers seem like they dont want much to do with them. If youre around Central Illinois I can pop test them for you. I have a nozzle checker.
Dover
11-03-2007 15:36:12
It might just need the injectors cleaned. You could try a couple cans of injector cleaner in the diesel
Mike r.
11-05-2007 08:07:19
 Re: G1050 sputtering in reply to Dover, 11-03-2007 15:36:12
The tractor is located in southwest Tennesee. I had a mechanic come look at it and he is convinced it needs the injectors rebuilt. I did not get a price quote yet, but I don't think it will be too bad. I suppose a T/A or engine O/H would be considerably more expensive to fix. I think it will be worth it to repair, it has a lot of life left in it.
millard hayes
11-07-2007 19:16:02
 Re: G1050 sputtering in reply to Mike r., 11-05-2007 08:07:19
Where in Tenn. do you live I would like to see your tractor
jp88
11-05-2007 14:26:21
Hey Mike have you been to Jackson Diesel yet?A buddy of mine and I went there once and they checked his for free and even let us go back and watch the process.They rebuilt his on the Perkins and I put them in(1850 Oliver).I talked with the owner and he was a very nice fella.Jack(TN).
Mike r.
11-07-2007 18:54:43
 Re: G1050 sputtering in reply to jp88, 11-05-2007 14:26:21
Thanks for all the info fellows, it's been mighty helpful. I found a retired Oliver/MM mechanic who is going to "clean out" the fuel system in my 1050. He is pretty convinced it wont take more then a good cleaning and maybe a rebuild kit for the injectors. Supposedly I wont be going over a 4-500 dollar repair tops.
Im glad it wont be a horrible repair or impossible to get parts for. I really like th tractor, it runs circles around our 4320 Deere. The old girl has 8,600 hours on the meter so I guess she has earned some TLC.
