Minneapolis Moline Tractors Discussion Forum
MM UTU 1945-47
Michael Link
10-31-2007 09:17:00
I have a 1945-47 I have to check the serial number. But I am over hauling the hydualic system. It uses the orginal gear driven pump to run the system. I pulled off the pipes and hoses and fluid tank. I am looking for the gasket that goes between the oil pump to the pipes. I have rebuilt the whole engine and block from the ground up so the pump and everything with that is good to go. Any info is welcome. Mike Contact me at [email protected]
T.R.K.
11-01-2007 19:23:48
 Re: MM UTU 1945-47 in reply to Michael Link, 10-31-2007 09:17:00
That triangle gasket at the back of the pump?
Call Welters in Verona MO. 417-498-6496. They also have the flat O-rings, but I have had problems with them bursting.
