Minneapolis Moline Tractors Discussion Forum
R Moline Parts
R Moline
10-29-2007 17:50:15
I have lots of good parts for an R. I have 4 good jugs. One set are 20 over. I also have the pistons that go with the 20s. I have lots of stuff let me know if you need anything.
kevin ely
11-05-2007 16:20:19
 Re: R Moline Parts in reply to R Moline, 10-29-2007 17:50:15
Anyone know where I could find a head for a model u, ge 30e cast #
dlp
10-30-2007 16:49:01
I need the oil pump 12t gear & the 24t cam gear so I can run a mag. Do you have a set & I'm in NW Arkansas. Thanks!
R Moline
11-01-2007 11:18:44
 Re: R Moline Parts in reply to dlp, 10-30-2007 16:49:01
Is the cam gear a small one or large. Its been a while since I"ve been into one. I know I had to change the gears to run a dist. on mine.
dlp
11-01-2007 15:11:06
 Re: R Moline Parts in reply to R Moline, 11-01-2007 11:18:44
The small gear on the end of the cam drives the smaller gear on the oil pump shaft. The small gear on the cam will be a 24 tooth & the oil pump shaft gear will be a 12 tooth for a magneto.
R Moline
11-01-2007 18:08:51
 Re: R Moline Parts in reply to dlp, 11-01-2007 15:11:06
Ok I do have the gear that came off the camshaft that is for the mag. I also have the shaft with the gear on it that turns the mag. It runs from the oil pump to the mag and is turned by the cam gear. They both came out of a running magneto engine that I changed to a dist. I'll take $100 for both or make me an offer.
dlp
11-01-2007 18:39:55
 Re: R Moline Parts in reply to R Moline, 11-01-2007 18:08:51
I'm afraid I will have to pass. I couldn't even make an offer close to that. Thanks for your time.
R Moline
11-01-2007 19:20:52
 Re: R Moline Parts in reply to dlp, 11-01-2007 18:39:55
How about $50 for both plus shipping. I really have no use for them and if you can use them and if you can use them, you need them more than I do
dlp
11-02-2007 04:34:25
 Re: R Moline Parts in reply to R Moline, 11-01-2007 19:20:52
I could go $30. I don't need the shaft so it would make shipping a lot easier.
R Moline
10-30-2007 19:27:26
I know I have the mag cam gear and I'm pretty sure I have the oil pump gear but I'll have to check on that.
Clint Youse MO
10-29-2007 19:28:17
How about a good hood and a gas tankneed the two piece tank and hood to match with hinged side curtains. If you do how much and where at?
Kevin Moschenrose
10-31-2007 22:06:40
 Re: R Moline Parts in reply to Clint Youse MO, 10-29-2007 19:28:17
Clint I live 70 miles east of St. Louis. I have a good gas tank and a hood. The hood hinge is rusty and stuff but I think it would loosen up.
R Moline
10-30-2007 13:07:56
I don't have any good sheet metal. Sorry.
Lindsey Raddatz
10-29-2007 18:45:27
do you have the clutch out, I need a piece, but not the whole thing?
R Moline
10-30-2007 13:09:04
 Re: R Moline Parts in reply to Lindsey Raddatz, 10-29-2007 18:45:27
I wound up having to use the clutch out of the parts in my pulling tractor. Sorry.
molinebob
10-29-2007 18:07:36
You wouldnt happen to have the piece for the hand clutchm the one that goes on the shaft on the outside of the transmission, where the rod from the hand lever connects to, if so how much would you want for it.
Kevin Moschenrose
10-31-2007 22:04:06
 Re: R Moline Parts in reply to molinebob, 10-29-2007 18:07:36
Bob, I have one! 20.00 plus shipping.
molinebob
11-01-2007 12:19:43
 Re: R Moline Parts in reply to Kevin Moschenrose, 10-31-2007 22:04:06
That is same as the one on the UTS correct, the center hole should be 1" and the keyway slot should be 1/4" at least that is what mine is. If they are the same email me at [email protected] so I can get your adress and send the payment out asap. Thanks for your time.
R Moline
10-30-2007 13:11:57
That was busted on this one so I dont have that. I had to find one too. If you are close to Arkansas I know where several are.
molinebob
10-30-2007 14:34:21
 Re: R Moline Parts in reply to R Moline, 10-30-2007 13:11:57
No I am not close to Arkansas, I live about 6 miles from the Canadien border in northern Minnesota
