Minneapolis Moline Tractors Discussion Forum
M5 rear end
Junkman
10-26-2007 10:23:39
My M5 rear end broke under the right axle on the bottom of the case & a big chunk is gone. Don't know how that happened. Have not used machine much since purchased, maybe 2 hours. Any one around st. louis have an m5 rear end with 3 point? Or what will work? Thanks
Luke Miler
10-30-2007 16:41:36
 Re: M5 rear end in reply to Junkman, 10-26-2007 10:23:39
I sent you an email the other day. I have a M5 tractor for parts. The rear end is complete. It has type E hydraulics which can be switched out for you 3pt hyd system. I am around springfield, il. Email me at [email protected]
Ill John
10-30-2007 05:09:45
Junkman, I'm in NE Illinois, have an early one. I don't have it home yet but it has 3 point and internal plumbing. Going out of town for a week, will get it home when I get back, if you haven't found anything, send me an email. Thanks, John
MM Guy
10-27-2007 08:06:02
The early M5 had the same rear end as the 5 Star with the internally piped hydraulics. The later M5s had the same rearend as the 602s. I believe you can even make the 670 rearends work as well.
Junkman
10-27-2007 08:24:22
 Re: M5 rear end in reply to MM Guy, 10-27-2007 08:06:02
This machine is a 61 model. What is the give away on which hydrualic is which? I don't have any manuals yet. Thanks
MM Guy
10-27-2007 16:09:50
 Re: M5 rear end in reply to Junkman, 10-27-2007 08:24:22
If it has the internally plumbed system, there will be a single small (1/2 dia) line exiting the pump to the rhs of tractor. The external systems has two large lines and one small line coming from the pump.
