Minneapolis Moline Tractors Discussion Forum
Bolt in transmission cover
Jerry Grant
10-25-2007 07:55:45
On my 46 ZTN, directly behind the gear shift lever is an L shaped bolt threaded into the transmission cover and extending into the transmission case. The bolt has a screw driver slot and a nut on the top for adjusting and setting. It does not appear in my parts manual or my shop manual. What is it for? It must adjust for something?
Jerry Grant
10-25-2007 17:54:57
 Re: Bolt in transmission cover in reply to Jerry Grant, 10-25-2007 07:55:45
I have checked it out. You guys are right on. Thanks so much for the assistance.
Joe Leising
10-25-2007 09:43:17
Is it in-line with the 5th gear selection? It could be a lock out for road gear if the tractor is equiped with steel wheels. Just guessing at this point.
Joe
Jerry Grant
10-25-2007 10:19:48
 Re: Bolt in transmission cover in reply to Joe Leising, 10-25-2007 09:43:17
My 46 Z never had steel wheels. Well, I guess I should never say never. Who knows for sure 61 years ago. I doubt many tractors were made after the War with steel wheels. However, your idea is the best suggestion I have heard so far. The L bolt is just to the side of the bracket that seperates the sifter shafts, so not sure how it could keep it from going into 5th gear. I will check it out.
Alan K
10-25-2007 10:46:01
 Re: Bolt in transmission cover in reply to Jerry Grant, 10-25-2007 10:19:48
That sounds right what Joe said on the 5th gear lock out. They did have that on the tractor I believe whether you had steel wheels or not.
