Minneapolis Moline Tractors Discussion Forum
UB 9 bolt hubs
KyleMM
10-18-2007 10:44:57
Does anyone know what 9 bolt hubs will fit on the back of a ub Moline?
KyleMM
10-19-2007 18:52:20
 Re: UB 9 bolt hubs in reply to KyleMM, 10-18-2007 10:44:57
Thanks for the replies.
jd plowboy
10-18-2007 17:09:59
my brother put a set off a 1650 oliver on his u moline. he did a liitle grinding on the edges where it fits the axle. he also done a little grinding on the keyway in the axle but the hubs had the 3/4 keyway. it was a lot cheaper and easier than anything else he found.
KLS
10-18-2007 15:53:17
I found a pair of what I believe are Oliver hubs that fit on mine. They are white and held on with three "U" bolts, you will need to make a custom key, the keyway on a UB is 3/4" these hubs come with a 1/2" key cast on them.
