Minneapolis Moline Tractors Discussion Forum
M.M G puller
Cast Iron Dave
10-09-2007 19:00:59
HI guys, Getting ready to restore and make a puller out of a GB. Is there any front hubs and wheels off any other tractors that would fit on the G to make it Lighter? Heavy cast Iron ones on there now. Also what has everyone done about the rear wheels. Would like to put 9 bolt pressed steel on it. Do I need to make a homemade hub to fit on the cast Iron hub? (tappered axles) any help would be great, thanks.
ejr-IA
10-10-2007 08:19:10
 Re: M.M G puller in reply to Cast Iron Dave, 10-09-2007 19:00:59
I have seen G's with the U standard front end which is lighter.Does the G have the splined axles like the GVI if so I'm told that F30 Farmall hubs will fit the splined axle and then drill the nine hole pattern in them.
