Minneapolis Moline Tractors Discussion Forum
MM Hydraulics
Teebogr81
10-09-2007 12:43:50
From reading some posts here, and some from experience with my UB, I understand there is something a little different or special about the way the hydraulic pump and original cylinder work with the M&M's. I used a neighbor's folding spring tooth a couple weeks ago and found I couldn't quite lift it (his cylinder). I also discovered that when using a fertilizer cart the cylinder on the cart would not stay extended after I released the valve. Any hints on what is different or how to use non M&M cylinders with my UB?
ken in texas
10-10-2007 18:17:12
 Re: MM Hydraulics in reply to Teebogr81, 10-09-2007 12:43:50
check with Tractor Supply ,or most any tractor dealer and see what they might have..... ...
Curt Cooke
10-10-2007 07:01:38
Northerntool.com and there about $60 as I recall.
Teebogr81
10-10-2007 06:29:32
Any idea where I can get a control valve or how much I'll have to pay for it?
ken in texas
10-09-2007 18:24:06
The MM cylinders have internal control valves to holdthem in position,where others do not.I once used an after market control valve plumed into hyd system and operated a Cross brand cylinder,whitch worked ok..... .
