Minneapolis Moline Tractors Discussion Forum
ZAU/convert back to orginal generator/regulator
Jerry Wallen
10-07-2007 12:06:26
I have a zau I am restoring and need to find a generator,generator bracket, voltage regulator and wiring harness ( for pattern to make new) to put it back orginal--where can I find parts? thanks Jerry
Ill John
10-08-2007 19:44:19
 Re: ZAU/convert back to orginal generator/regulator in reply to Jerry Wallen, 10-07-2007 12:06:26
If you would include your area or address, we could help much sooner. I have many parts like that but I don't ship too many. MOTEC has the harnesses, they are very good for the leter series. Go to minneapolis-moline dot com, look under parts suppliers, lots of commercial help out there.
T.R.K.
10-08-2007 10:52:52
Motec has some good wiring harnesses. 765-963-6628.
For generator, there is always Ebay. Other good sources would be Don Rice 585-243-2617, Wendell Everett 740-922-3335, Welter's 417-498-6496.
They could also help with regulator, but I always got mine from NAPA or local generator rebuilder. You probably should have generator checked out before you install it. There is always some risk with used parts.
