Minneapolis Moline Tractors Discussion Forum
Moline power experts
W3
10-04-2007 14:34:26
Have been gathering moline parts for awhile. Have a UTU l.p. with 10a4206 heads and 10a149 blocks,10a1700 crankcase and a 283-4a power unit, with ke151g crankcase [g bellhouseing?] ge101 blocks , ge30j heads and a G short block 403a with 10a150a blocks and le151 crankcase also a set of 10a4232 heads and a set of 10a2196 blocks [504? 4 5/8]. Want to build a mild puller. What is the best combo? Big blocks and g crank of course. What makes more proven torque long rods long blocks, or offset ground crank, short rods and blocks? Want to stay l.p. Are the 10a1700 and ke151g crankcases interchangeable? Starting with a clean slate would like to hear from you MM expert builder. Thanks William
jd plowboy
10-06-2007 10:27:29
 Re: Moline power experts in reply to W3, 10-04-2007 14:34:26
try this on the tractor pulling discussion forum. you would probably have more people that have done this
