Minneapolis Moline Tractors Discussion Forum
whats this
kendak
10-03-2007 18:40:57
Don't know anything about MM but found one near complete ...LP model...4 cyl....plate on left side of engine reads Model 4 1/2 X 5 283A 4....serial # 01909288...no markings on sheet metal but MM cast in rear wheel hubs....what is this??? I can get it for scrap price...thanks ...Kent
shinnery
10-03-2007 23:04:50
 Re: whats this in reply to kendak, 10-03-2007 18:40:57
Probably a UT or UB. That plate is for the engine only, there should be a plate on the side of the transmission that will give the tractor model and seial number. I think on my UB without going out in the dark to look it is sorta behind the brake pedals. Then you can check over on the left where it says Serial numbers or go to www dot minneapolis-moline dot com they have a good serial number file.
It is about a 50 hp tractor and worth getting IMO.
Bryce
