Minneapolis Moline Tractors Discussion Forum
Gvi diesel fuel filter problems
toolz
09-22-2007 18:45:33
I'm a Gvi rookie, and I need some help. Went to NAPA for the fuel filters- they sold me 2. I took off the first canister and there was nothing in it. The element NAPA sold me doesn't fit, either. Is this a sediment can, or is there supposed to be a filter there? The other filter was right, but I dropped it and broke the glass bowl on the bottom. Is this part available, or is there something better than glass to put in it's place? I need to solve this problem right away, so any help or sources for this stuff would be appreciated. Thanks- Kevin
toolz
09-23-2007 20:34:52
 Re: Gvi diesel fuel filter problems in reply to toolz, 09-22-2007 18:45:33
Thanks for the reply. The pump is a Roosa master. The fuel passes through the first canister that was empty, and then through a filter with a glass bowl mounted on the bottom of it. A long center bolt passes up through the glass bowl and filter, threading into the housing. I need that glass bowl, and don't know what that first canister is for. I appreciate your help, since I have no experience with MM. Thanks again- Kevin
Kevin Moschenrose
09-23-2007 21:38:18
 Re: Gvi diesel fuel filter problems in reply to toolz, 09-23-2007 20:34:52
Kevin, I believe that the first canister is where a reusable clean out screen is to be at. The one you said is empty. It is made of a very fine wire tube and just sets in there. I am not sure how may microns it filters to or anything like that. I know you just wash them out and replace it. It is to be used as your primary filter.
Nebraska K
09-23-2007 20:12:00
What fuel system does your GVI have? Does it have an American Bosch pump or a Roosa Master? The Bosch has three fuel filters. The Roosa has only one. Let me know mabey I can help from there.
