Minneapolis Moline Tractors Discussion Forum
Model ZTU
Chandler Watson
09-20-2007 16:43:45
I have a model ztu. I need info on the year and hp rating. I know it is a RF engine. The Serial #528137u. Any and all info would be helpful. Thankyou
BMG1
09-20-2007 17:58:20
 Re: Model ZTU in reply to Chandler Watson, 09-20-2007 16:43:45
Chandler,
The ZTU used an RE engine. You probably can't make out the bottom of the "E" on the tag. The number you listed does not match up with a ZTU. Take another look at your tag. RE engine serial numbers are only five digits through 1948. ZTU tractor serial numbers are six digits but started with 560001-585817. Since you listed a "u" at the end of your number I assume you've posted the tractor serial number. Could you have the "8" and "2" switched at the beginning of the number? If you meant 582137u then its a 1948 model.
Brian
