Minneapolis Moline Tractors Discussion Forum
MM GB lp
sdbern
09-20-2007 09:54:47
need to replace ensign model R system. What do I replace it with.
Ill John
09-21-2007 17:44:14
 Re: MM GB lp in reply to sdbern, 09-20-2007 09:54:47
I'm using a model J Impco and a 100 carb, easy to work with, can be set up in about any configuration. Mine is on a M670 which had an Ensign.
sdbern
09-21-2007 22:54:22
 Re: MM GB lp in reply to Ill John, 09-21-2007 17:44:14
thanx alot from reading the board I kind of thought that was what I was going to hear. thanx again
MnM44
09-21-2007 06:57:38
Use a model E impco regulator and a model 100 carb if it is stock cid.
sdbern
09-21-2007 22:58:40
 Re: MM GB lp in reply to MnM44, 09-21-2007 06:57:38
It is standard cid. I want to keep it as close as I can to origional thanx.
