Minneapolis Moline Tractors Discussion Forum
U302/220 cylinder thickness
Mopower
09-18-2007 10:58:25
How far can you bore a 220 engine with that standard 3.75 cylinder before you break through? I would like to install 4" pistons if possible.
LW
09-18-2007 17:27:43
 Re: U302/220 cylinder thickness in reply to Mopower, 09-18-2007 10:58:25
YOu Can bore to 4.00 if you feel like .075 walls are adequate????? ????
Mopower
09-19-2007 04:44:40
 Re: U302/220 cylinder thickness in reply to LW, 09-18-2007 17:27:43
YIKES!!! You push things to the max. What do you recomend? I think 3.91 Chevy pistons are out there.
LW
09-19-2007 18:30:04
 Re: U302/220 cylinder thickness in reply to Mopower, 09-19-2007 04:44:40
No I don't push gray cast iron that far but you can If you want! I think you could go 3.910 yes, How many times have you asked me this?????
Mopower
09-20-2007 04:52:31
 Re: U302/220 cylinder thickness in reply to LW, 09-19-2007 18:30:04
Don't recall. Everyone tells the same thing. "Probably could go 4.0" but I've never heard the limit or any hard numbers. Thanks! As for minimum cylinder thickness? I probably asked ya a million times before yeah. I heard preferably 1/8 or more thickness for most folks. My buddy took a Z to 3.875. I believe it finally cracked.
buzzuca
09-18-2007 12:06:59
please call doug henderson
Mopower
09-18-2007 12:18:59
 Re: U302/220 cylinder thickness in reply to buzzuca, 09-18-2007 12:06:59
Talked to him last evening. Why?
